How can I test / measure the NI DAQ 6527 board output
Hello everybody
How can I test / measure the NI DAQ 6527 board output ?
When I run the folowing code I cant see / measure the output on the 'Dev1/port5/line0:7' chanel.
If anyone knowns some method please help me, because on the selected 'Dev1/port5/line0' chanel I can't measure any voltage difference.
Thank you for any advise.
#include <unistd.h>
#include <stdio.h>
#include <NIDAQmx.h>
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
int main(void)
        int32       error=0;
        TaskHandle  taskHandle=0;
        uInt8       data[8]={1,0,0,0,0,0,0,0};
        char        errBuff[2048]={'\0'};
        int         i = 0;
        // DAQmx Configure Code
        DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
        DAQmxErrChk (DAQmxCreateDOChan(taskHandle,"Dev1/port5/line0:7","",DAQmx_Val_ChanForAllLines));
        // DAQmx Start Code
        DAQmxErrChk (DAQmxStartTask(taskHandle));
        // DAQmx Write Code
        while(i++<60)
        data[i%8] = !data[i%8];
        data[0] = 1;
        printf("Write ports sample No...[%d] - ", i);
        printf("data[");
        int j = 0;
        for(j=0; j<8;j++)
          printf("%d ", data[j]);
        printf("]\n");
        DAQmxErrChk (DAQmxWriteDigitalLines(taskHandle,1,1,10.0,DAQmx_Val_GroupByChannel,data,NULL,NULL));
        printf("Write end \n");
        uInt32 data_r = 0;
        int32  read_r = 0;
        DAQmxErrChk (DAQmxReadDigitalU32(taskHandle,1,10.0,DAQmx_Val_GroupByChannel,&data_r,1,&read_r,NULL))
        printf("Data acquired: 0x%X\n",data_r);
        sleep(1);
Error:
        if( DAQmxFailed(error) )
                DAQmxGetExtendedErrorInfo(errBuff,2048);
        if( taskHandle!=0 ) {
                // DAQmx Stop Code
                DAQmxStopTask(taskHandle);
                DAQmxClearTask(taskHandle);
                printf("DAQmx Error: %s\n",errBuff);
        printf("End of program, press Enter key to quit\n");
        getchar();
        return 0;
(3,166 Views)
Please help me somebody whit an functional electric schema ...
(3,155 Views)
Hi hdarkspirit,
The PCI/PXI - 6527 is able to do Digital Inputs and Digital Switch Outputs. It is able to switch voltages of upto 60 VDC (30 Vrms AC) and currents of upto 120 mA. To be able to measure a digital output you would have to provide a voltage or current source. You can connect the source either in a Sourcing or Sinking configuration, depending on where you place your load. You can find the user manual here. Pages 3-10 to 3-12 talk about how to make the signal connections for a switch output. Appendix A has a all the specifications for this card including the On Resistance and Output Capacitance.
If you are programming in LabWindows CVI take a look at some of the Digital output examples that can be found in the Example Finder. You can find example programs written in C at C:\Program Files\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Digital\Generate Values. These example programs should give you a good idea on how to go about programming for Digital output.
Have a good one.
Malay D
National Instruments.
Message Edited by 50ohmTerminator on 10-09-2006 10:57 AM
Message Edited by 50ohmTerminator on 10-09-2006 11:01 AM
(3,142 Views)
Thanks.
The problem is solved with the help from an electrician engineers whitch undersand the electric schema.
At this moment evriting is ok.
THANKS.
(3,123 Views)
