How can I use LabView to collaborate Dmm and USB 9219 data?
Hello All,
I am very new to Labview (I have mostly just used already written code). I have a USB 9219 DAQ unit that I am using to measure Load via a SMD S100 load cell. I also wish to use Labview to provide an excitation voltage (via the USB 9219) in the form of a changeable function (probably a step function or a square wave in the +/- 3V range). I also have an HP 34401A digital multimeter (Dmm) that I wish to use to measure voltage and current with. Finally I have a Fotonic sensor to measure displacement.
the Fotonic sensor and load cell each provide a voltage (which will translate to displacement and load respectively) which I think I can figure out how to measure (and log) vs. time via the USB 9219. The problem is, I am having a hard time using LabView to log the Dmm data and also output a voltage (via the USB 9219). Also, I know I haven't a clue on how to get all the data "on one page". By that I mean, getting all the measured data  vs. the same time measurement.
Any help would be greatly appreciated.
Thanks in advance,
-Lou
Message 1 of 1
(2,720 Views)
