How can I use NI 4350 with USB on Win NT?
I have NI 4350 hooked up to WIN NT via USB. I'm using LabView 6.1 and am wondering if there are any suggestions as to how to interface them.
(2,647 Views)
M3b7,
I performed a quick search in LabVIEW and found four example programs. Simply Launch LabVIEW and click Find Examples on the splash screen. Next click on the Search tab and type 435x in the box. Click on 435x in the list and you will see four example programs.
You can also search for example code online by going to www.ni.com/support and choosing Example Code under Option 3. Type 4350 and click Go. Six example programs should appear.
You can open and modify these to suit your application needs.
Good luck with your application.
(2,647 Views)
Windows NT does not support USB peripherals. Your best bet is to switch to Windows ME, 2000 or XP. Is another computer available with 2000 or XP?
Michael Munroe, CLD, CTD, MCP
Automate 1M+ VI Search, Sort and Edit operations with Property Inspector 5.1, now with a new Interactive Window Manager!
Now supports full project automation using one-click custom macros or CLI.
(2,647 Views)
