How can I use the PCI-4451 installed in a laptop?
I would like to configure a sound level meter using a laptop and PCI-4451. I need a portable and rugged system to be used in the field. What are my options? Can I use the Configurable Signal Conditioning Enclosure CA-1000?
Thanks again.
(2,654 Views)
The CA-1000 does not contain a PCI bus interface for cards like the PCI-4451. The CA-1000 accepts a variety of signal conditioning modules and is then connected by cable to an acquisition device.
To use the 4451 with a laptop, you would need a Cardbus to PCI expansion chassis, such as those offered by MAGMA and other companies. I mention MAGMA only because I have a small amount of experience with their products. I'm sure there are others that are equally suitable.
If you're not 100% attached to the 4451, there are a couple other options. You could use a 1394 based DAQ device such as the NI DAQPad-6052E for FireWire, which could then be co
nnected to something like the CA-1000 if necessary, depending on your signal specs. Keep in mind that even though both the 4451 and 6052E are nominally 16-bit boards, the 4451 would be more suitable for audio measurements, particularly if you need simultaneous measurements on more than one channel.
Finally, a portable PXI system with the 4472 would make an ideal platform for precision audio measurements, if this fits within your budget and your definition of portable.
Brent R.
(2,654 Views)
