How can I wire AT-MIO-16E-2PG to load cell?
Hi. I have a AT-MIO-16E-2PG DAQ card. But I'm not sure this works with load cell or not. Let me know AT-MIO-16E-2PG is available to get load cell signal. If it is possible let me know how I can wire this to load cell.
Thanks.
(2,492 Views)
The AT-MIO-16E-2 is not designed to work with load cells. However, you can use one of the analog output channels to generate the excitation voltage needed, and connect the other terminals to an analog input channel.
RamziH.
(2,492 Views)
