How can i use the onboard memory from NI6534
I want to use the onboard memory of PCI 6534,but i don´t how can i put my data on this memory? are there function or command for that?
thank you.
Armand
(2,485 Views)
Armand,
Please reference the User Manual for the PCI-6534. Specifically, pages 2-10 and 2-22 in the Continuous Output sections explain how to leverage the onboard memory using either LabVIEW or the NI-DAQ C interface. For LabVIEW you will set the Pattern Generation Loop Enable attribute to ON in the DIO Parameter VI.
653X User Manual
http://digital.ni.com/manuals.nsf/websearch/EDE443F5C700373A862569B90072D26F?OpenDocument&node=4575_US
Justin Britten
(2,485 Views)
