Hello;
You probably accomplished that task by having a Software based application in VC++. The correct way to do that is to use a counter board, and configure two counters of that board to execute a retriggerable pulse train, and then, the pulse train would be routed trhough the RTSI bus to be the PCLK of the 653x board.
Regards
Filipe A.
