How connect 3-line Pt resistance temperature sensor to USB-6361
I want to connect 3-line Pt resistance temperature sensor to the NI USB-6361 by AI terminal.
My question is : How to connect the three lines?
(2,048 Views)
The USB-6361 is not equiped for resistance measurement.
Easy way : buy an industrial  pt?? to voltage (10V) converter that fit your measurement requirements
Greetings from Germany
Henrik
LV since v3.1
(2,007 Views)
Or an NI 9217 and a NI cDAQ-9171, which will be a much more expensive solution than a converter.
(2,003 Views)
