How do I assign a variable name by a string
I would like to assign an array name by a special string when loop is running.
Please look an attached file.
I mean,  "lavel name assign" named for "output array".
For example, when the loop run at first time, the name of "output array" will be Y1-data.
How can I do for it ?
Please let me know.
Thank you.
(3,094 Views)
You cannot change a label at runtime. You can change the caption by simply writing to the Caption.Text property.
(3,092 Views)
