How do I calculate the power and temperature of this microwave signal acquired by the radiometer I built?
Hi all!
I'm working on building a radiometer. The ultimate goal is to measure the temperature of the desired object. To do that I have to first know the power radiated by that object.
My solution is to build a radiomter. The structure of the radiometer is shown in this graph:
So I have a scalar feed horn receives the microwave signal radiated by the object, the frequency of the signal is converted from 12.45GHz to 1.2GHz by the LNB. The signal is feed to a spectrum analyzer. The 10MHz output of the spectrum analyzer is feed to a RF Millivoltmeter. The analog output is feed to NI USB-6002. Finally the signal goes into my computer.
I have two questions:
1. How do I know the power of the signal that goes into my computer. I can find the voltage of the signal by NI DAQmx. Then I think I have to know a resistance since P=(V^2)/R? The only resistance I can find in the system is the load resistance of 50 ohm from the probe of RF Millivoltmeter. So is the power of this 12.45GHz I acquire = V(value from NI DAQmx)squared/50?
2. I found in several papers that Power = k(boltzmann's constant) * T(temperature in K) * B(bandwidth). Therefore I also have to know the bandwidth of the signal to calcualte the temperature of the object. Which bandwidth am I supposed to look at in my case? Because the original signal is processed through several steps. I'm confused about which bandwidth I should be looking at.
Thank you for your patience! Any help is greatly appreciated!
(2,789 Views)
Accepted by topic author hiphip
Hi,if you want to measure the power that goes into your computer through USB-6002, I do not recommend you use V^2/R because this formula is used for pure resistance system where all power is transformed to heat. You may also have to measure the input current.
As for P=kTB, I think it is usually used in calculating the power of thermal noise.
(2,712 Views)
