How do I change the interchannel delay setting in LabView 8.2 for the USB-6008?
How do I change the interchannel delay setting in LabView 8.2 for the USB-6008?  I see a few threads for earlier versions, but I cannot find those menus in the new 8.2 version.
(2,811 Views)
Hi Wayne-
The USB-6008 only allows a fixed convert clock rate (  where convert clock rate = 1/<interchannel delay>  ) of 48kHz.
For other device that do support configurable convert clock rates (M Series, E Series, etc), that setting is made in LabVIEW via the DAQmx Timing Property Node, as shown here:
Hopefully this helps-
Message Edited by Tom W [DE] on 03-26-2008 10:00 AM
Tom W
(2,798 Views)
