How do I convert Traditional DAQ Trigger configurations that uses "I/O connector" input to DAQmx?
I am converting a lot of old Traditional DAQ code to DAQmx, and the digital write is configured to trigger on "I/O connector" with the trigger condition "Rising Edge". I'm not sure how to convert this to DAQmx (or exactly what it means). There seems to be nothing exactly like it in DAQmx.
(2,867 Views)
Hi Laurel,
Here is a list of documents you will find most useful making this transition:
Transition from Traditional NI-DAQ to NI-DAQmx in LabVIEW
https://www.ni.com/en/support/documentation/supplemental/06/transition-from-traditional-ni-daq--lega...
Learn 10 Functions in NI-DAQmx and Handle 80 Percent of Your Data Acquisition Applications
https://www.ni.com/en/support/documentation/supplemental/06/learn-10-functions-in-ni-daqmx-and-handl...
This VI should do what you would like.  You will jsut need to specify where you are bringing in the trigger; this will be a PFI line most likely (PFI0) rather than the IO Connector.
DAQmx Write Digital Channel- Internal Clock with Digital Start Trigger  (You will need both VIs)
https://forums.ni.com/t5/NI-DAQmx-Examples/DAQmx-Write-Digital-Channel-Internal-Clock-with-Digital-S...
Best,
Adam
Academic Product Manager
National Intruments
(2,836 Views)
