I looked around in LabView and couldn't find the DAQmx Delete Saved Global Channel vi or the DAQmx Delets Saved Tasks vi. In fact I can't find the Save versions of those vis either - I think that the Save Gloabl Channel vi that I'm using came from the "Programmatic Saves of NI-DAQmx Tasks, Channels, and Scales Example" that you pointed me at earlier.
Once the examples are loaded into LabView they work fine, but it seems odd that the Linux version wouldn't have vis that seem as basic as that.
When I do: nidaqmxconfig --export test.txt and look at the text.txt file it generates, I find lines for the digital output modules that look like:
[DAQmxSCC SCCA-DO1]
ProductType = SCC-DO01
SCCModule.ConnBlk = SCCA
SCCModule.slot = 9
I've also got SCCA-DO2 in slot 10 and SCCA-DO3 in slot 11
SCCA is the SCC-2345 connected to DAC16A, the first (of 2) PCI-6221 cards. I can see the analog channels without difficulty. The system also has a PCI-6122 in it, but it is using its BNC breakout box.
thanks,
Chris
