How do I get an analog output signal from my PCI-MIO-16E-4 card?
I need an analog output from 0-10 V to control the mass range on a mass spectrometer. Do I use the DAC0out channel to do this? The manual only talks about analog out (ao) channels. Is this the same as DAC0out and DAC1out? How do I set up the DAQ assistant for this process? I do not need a waveform, only a constant signal.
(2,893 Views)
Yes indeeded. The DAC0out and DAC1out are the analog output channels (ao0 and ao1).
Simply follow the examples that ship with LabVIEW. You can also easily create code with DAQ assistant.
(2,891 Views)
