How do I get my DAQPad-6020E channels to show up in LabView7?
When I try to access my DAQPad-6020E using the DAQ Assistant Express VI in LabView 7 and I go thru the configuration it tells me that there are no physical channels available. How do I get the DAQ channels to show. All the other NI software sees the DAQ and the channels when I run the diagnostic tests for the device.
(2,432 Views)
Please try the following fix for this issue:
Click Here.
I hope this helps. Let me know if this fix does not work and you need further assistance.
Best Regards,
Joe Des Rosier
(2,432 Views)
