How do I ground a signal connected to an SCB68 pin board
I have connected the inner core of the BNC cable to the pin 68 and the external part to the pin directly below it 34. I have also pushed up the S5 and S4 switches to the upper position.   Do I need to do anything else?
When I am in MAX I go into
Driver Interface -- NI DAQmx device -- NI PCI -6052E: "Dev1"  Test panel and the analog is 0.214 and fluctuates slightly but even with the signal conditioner power switched on or off it is the same.
Also
Driver Interface -- Traditional NI DAQ(legacy) device -- PCI -6052E(Device1) -- test panel -- the analog input is 0.215 and again fluctuates slightly but even with the signal conditioner power switched on or off it is the same.
What do I need to do?
Message 11 of 12
(970 Views)
When you have your card installed if you select _calref_vs_aignd as the input channel do you measure 5V (shown below in the attached image)?  You can also try selecting ao0_vs_aognd, and generate a signal on the AO tab.  If this works, your card seems like it should be working.
I would also check to see if you are getting any signals from your device.  If you connect your cable connections to a DMM, do you measure anything?  Can you verify that your device is sending out the +/- 10V signal you are expecting?
Jesse O.
Applications Engineering
Message Edited by Jesse O on 02-09-2007 01:40 PM
Jesse O. | National Instruments R&D
Message 12 of 12
(958 Views)
