How do I link Labview with my 6013 DAQ
How do I link labview with my 6013 DAQ board,is there configuration that i need to do?
I using the data acquisiton>daq solution wizard
but i cant find my 6013 board.MAX can see my board and test it perfectly but somehow I cant see my board through labview.
Another question is how do use the channel 1 to connect the a waveform ground.I can only see three things inside the I/O:-sine,squre and temperature.
thanks, any help would be greatly apprieate.
(2,498 Views)
Halif,
Allow me to walk you through some basic steps to verify your board is installed and working properly, then I'll explain how to start working with LabVIEW.
First, to verify proper installation and operation of the board and driver, refer to the steps in the Hardware Installation Wizard: http://www.ni.com/support/install/. Read through them. If you have everything installed properly, there's no need to perform the steps again.
Then, launch LabVIEW. Your board, the PCI-6013, is currently only supported in NI-DAQ 7.0 Traditional and earlier (http://www.ni.com/support/daq/versions.htm). Therefore, the DAQ Assistant and NI-DAQmx VIs will not work with that board. Try running one of the example programs in the Help>>Find Examples under Traditional NI-
DAQ. Then just search for the type of application you have in mind.
Good luck with your application.
(2,498 Views)
