How do I maximize 6052E acquisition speed using 1394?
I have a 400Mhz PII, 294kbytes of memory, with IOGear GPF103 firewire card. I can't get my NI DAQPad 6052E to acquire a single channel faster than about 10 Hz, without the link hanging under MAX. LabView 7 fares no better. Is there any way to determine what performance I can expect from this system? Is there anyway to improve this performance without getting a new laptop? My 1.8Ghz desktop can run continuously at 10kHz sampling rate or better, but is too bulk to take to the field. Is there a better cardbus II 1394 interface card? (Win 2K, SP4 MAX 3.0, LabView 7.0)
(2,661 Views)
Greetings,
The 1394 driver on your system may not be using the correct 1394 adapter speed and/or internal FIFO size. There is a utility available on National Instruments website to manipulate these settings. It is located HERE. This should give you a place to start troubleshooting.
Good luck with your application.
Spencer S.
(2,661 Views)
Spencer, I appreciate the answer. I will download the utility as soon as I can get FTP access.
I have found an alternate 1394 card which works well. Trouble is that it is no longer available.
Do you have a list of PCMCIA (cardbus) 1394 cards which work well with the NI software out of the box?
(2,661 Views)
