How do I output 0-5 VDC using PCI-6723 board
I am using MAX 4.xx  test panels, and BNC 2110 with PCI 6723 AO, I would like to output 0-5VDC
to my HW for lighting LCDs. I do not want differential voltage, but with a single ended or GND,
Pls help how do I set up the circuit,I tried both GS and FS on the BNC 2110 , when not connected to
my Target HW, I can see the output from 6723, but when I connect the output to the target, it does not work
(does not light up the LCD panel)
Pls help
(2,761 Views)
How much current does the LCD panel require? How does this compare to the drive capability of the output of the 6723? If the current requirement is too high you will pull down the output  voltage and it will not work.
Richard
(2,752 Views)
