03-31-2009 02:15 PM
I need to be able to output a chirp (some short signal) to an amplifier and right after record on 8 analog channels. Recording the channels seems to be no problem, but I can't seem to find a way to create my own signal and output it via IOtech's DaqBoard3000. Is anyone familiar with outputing a created signal with this board? If so, is there an easy VI or what can I do?
I've done a lot of reading and tried to do a lot of searching, but just don't seem to be getting anywhere with this board.
03-31-2009 02:38 PM
03-31-2009 02:49 PM
I wasn't sure if this was NI boards only. Is there a forum for labVIEW support for non-ni boards? IOtech doesn't seem to have such a resource.
My problem is figuring out how to output your own, manually built signal. If I can get that far I'm sure I can figure out how make a working data structure. The only data output VIs I can find are those to create program defined waves (sines, saw, etc) in either a counted or continous format. I've really only been working with the included examples. Attached is one of the examples. I'm not sure if the subVIs are included.
03-31-2009 03:53 PM
You could try posting to the LabVIEW board.
What you need to find is a lower level function in the IOTech driver. Something that does a direct write and not just predefined waveforms. If the VI that generates the predefined functions is not locked or password protected, look to see what is being called.
