How do I read the voltage set on the analog outputs without setting it
I can set the analog output and read the analog inputs, Is there anyway to read what voltage is set to an Analog output with out setting it?
(4,433 Views)
Can you re-phrase the question?  That's like me asking if I can read my reply to this post without replying to it.  Smiley Surprised
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(4,420 Views)
I'm just trying to see if there is a way to query what voltage was set to an analog output.  I want set it in one vi, but read what was set in a different vi.  I just want to know if there is a way I can query what voltage the channel was set to previously (without creating a global variable when I originally set the output), Does this make sense?
Thanks for you help.
(4,413 Views)
What device are you using?  Most multifunction boards have an internal channel for AO vs ground.  On an M Series board, for example, you can read Dev1/_ao0_vs_aognd in an AI task.  When you create your channel constant/control in LabVIEW, right click on it and select "I/O Name Filtering...".  Make sure that "Internal Channels" is selected.
(4,405 Views)
I thought there might be a DAQmx property that could provide this but I don't see any way to do it.  In any case, it seems as you're going to have to at least pass a DAQmx reference to your subVI to do this (even with Mark's solution) so why not just pass the last value you wrote to the channel instead?
(4,400 Views)
