How do I set all Output pins at 0V when Labview is not in use?
I have a DIO pin connected to a Solid State Relay which controls 115AC. I want to make sure that the AC voltage does not flow to my heater unless I have my Labview Program running and I am sending a high TTL signal to the SSR. This should not be a problem since the user has to flip on a mechanical switch to use the oven, but should someone close the program, and forget to flip this switch off, I want to be sure that the TTL signal will not float high enough to allow the 115VAC to the heater.
In a round about way, I am trying to ask how to I make sure that the DIO pin is at gnd when Labview is not in use. It tends to float around 1.25V. Thanks.
(2,760 Views)
Rather than worry about setting the digital outputs with software, I have used a hardware resettable timer module, with its reset input triggered by a spare digital output. Should Labview stop/fail/or the computer lock up (it is windows, after all!!) the timer will time out without its regular digital reset pulse. Use a contact from the hardware watchdog timer (that is what this is called, BTW) in series with the digital control to shut off the drive to your SSR module.
I am using this any of my projects where I want failsafe operation.
Good luck
Dave
(2,754 Views)
