How do I set different A/D ranges for each channel in Nidaqmx
I have a PCI-6132 card and I want to collect data in warp-mode using Labview on all 4 channels with a single external trigger/clock source. I want each of the channels to operate in a different maximum voltage range, e.g. channel 0 +/- 10V, channel 1 +/- 1V, channel 2 +/- 200mV etc.
I can collect data on a task using "dev1/ai0:3", but I can't figure out how to set individual channel gains.
Do I need to set up 4 individual tasks? Can each of these tasks use the same external clock/trigger (on PFI0 and PFI7) resource?
Thanks -- Gerard
(3,202 Views)
You use a single task but four separate DAQmx Create Channel functions. You could also have a single DAQmx Create Channel inside a for loop and have arrays of ranges and channels.
(3,191 Views)
Hi Gerard,
You can also set up one task and just use that. This KnowledgeBase talks about how to set up different gains on the same channel, but you can easily apply the same concept to different channels.
Mark E.
Precision DC Product Support Engineer
(3,154 Views)
Thank you for the help. This works. -- Gerard
(3,109 Views)
