How do I set the excitation voltage on a NI 9237 to 3.3 volts?
Good morning,
The excitation voltage is at 2.5 volts now.
This is my first time working with this device.
Is this set in MAX or are there jumpers?
I want to set the excitation voltage to 3.3 Volts and not change it.
The NI 9237 is in a NI cDAQ-9172.
Bill
(4,280 Views)
Accepted by topic author Bill_5335
Hi POBA,
This can be set your programming environment.  For example, LabVIEW, Signal Express, a Task in MAX, or by a DLL call in a text based environment.  You will want to create a Strain, Custom Voltage with Excitation, or any bridge based task in any environment.
In MAX, right-click on your device and choose Create Task»Acquire Signals»Analog Input»...
In LabVIEW, place a DAQ Assistant»Acquire Signals»Analog Input»...
In Signal Express, Add a step for Acquire»DAQmx Acquire»Analog Input»...
In any C based language, you will want to call a function such as: DAQmxCreateAIVoltageChanWithExcit, DAQmxCreateAIStrainGageChan, DAQmxCreateAIBridgeChan
You can then specify the Exictation Source to be Internal at 3.3V.
Best,
Adam
Academic Product Manager
National Intruments
(4,255 Views)
Hi Adam,
I figured out what I was doing wrong.
  I have three strain channels set up.
     I needed to change the excitation voltage on all three channels.
     Once I changed each channel to 3.3 volts, the DAQ Assistant would close without showing an error.
I don't think I was as clear as I should have been.
Bill
(4,246 Views)
