How do I set the low pass analog input filter (anti-alias) on my DAQ Setup?
 I have read the following from the PXI-6251 manaual:
"On some devices, the filter cutoff is fixed. On other devices, this filter is programmable and can be enabled for a lower frequency. For example, the NI 628x devices have a programmable filter with a cutoff frequency of 40 kHz that can be enabled."
It doesn;t explain how you know this value. So I have the following questions:
1. How do I know what the cut-off freq is on my device?
2. How do I know if its programmable?
3. How do I programme it if it is programmable?
I am using the PXI 6251 in conjunction with the PXI 1031.
Many thanks.
(4,127 Views)
Accepted by topic author mea03wjb
The PXI-6251 has no anti-aliasing/programmable filter.The small signal bandwith (-3dB) of the 6251 is 1.7 MHz.You'll find this informations in the specifications manual.
If you need a filter, then you've to add the signal conditioning yourself.
The 628x M high accuracy boards are the only M series boards with "programmable" low pass filter. Check this KB for more details.
Hope this helps.
Luca
Luca
(4,101 Views)
Hi mea03wjb,
I hope your well today.
I was wondering if the advise Luca gave you answered your questions - it does the KB answers them in very good detail, and if you require any further support?
Thanks for your post!
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(4,056 Views)
Luca, thanks for your fast answer! It was all I needed to know, we are now in the process of building a programmable anti-alias filter for our test-rig now I know the 6251 does not have one.
Thanks again,
Will
(4,033 Views)
