How do I wire my SCXI-1520 quarter bridge completion in parallel?
I have a quarter bridge set-up using the qtr completion in the system. In parallel with my strain gauge I'd like to have another resistor. I'm using the strain gauge as a dummy, and am interested in the current traveling in a parallel path through a film resistor as I change the film thickness. However, I'm not convinced that what I've wired has the strain gauge and other resistor in parallel. I have the strain gauge wired to: P+, QTR, S+ and the other gauge wired to QTR, S+.
Thanks!
(2,561 Views)
Greetings,
You will want to wire the other gauge between P+ and QTR or between P+ and S+. To make this decision, you will need to determine how the lead resistances will affect your measurement. Page 2-4 of the SCXI-1520 User Manual (link available below) contains the wiring diagram for Quarter-Bridge Configuration I.
Good luck with your application.
Spencer S.
(2,561 Views)
