How do I wire the analog inputs to a PCI-6031E w SCB-100?
I am trying to connect my analog input signals(differential) to the PCI-6031e with a SCB-100 connector and need to know the pinouts.
Earl
Message 1 of 8
(4,361 Views)
Details for the pinout should be in the manual located at:
https://www.ni.com/docs/en-US/bundle/370503k/resource/370503k.pdf
Message 2 of 8
(4,349 Views)
Right.  I checked the manual prior to posting and it is still not clear which wire pairings go to which pins.  For example, I have 2 wires from a transducer, where do they go for Channel 0, Channel 24 etc?
Earl
Message 3 of 8
(4,343 Views)
From the manual:
  NI 6031E, NI 6033E, and NI 6071E only
For these extended AI devices, the AI signals are AI <0..63>, AI SENSE, AI SENSE 2, and AI GND. In single-ended mode, signals connected to AI <0..63> are routed to the positive input of the PGIA. In differential mode, signals connected to AI <0..7, 16..23, 32..39, 48..55> are routed to the positive input of the PGIA, and signals connected to AI <8..15, 24..31, 40..47, 56..63> are routed to the negative input of the PGIA.
And by looking at the pinout of the card, channel 0 would use AI 0 (+) and AI 8 (-), which are pins 3 and 4 respectively. The SCB-100 should be a 1:1 direct wiring scheme, so use terminals 3 and 4. You may need bias resistors for DIFF mode, please look at the manual.
Good Luck
Message 4 of 8
(4,342 Views)
Thanks for the re-explanation.  I didn't realize that the pins for each channel were next to each other and I really didn't understand the manuals explanation.
Earl
Message 5 of 8
(4,329 Views)
Your'e welcome!
Hope the acquisition is going well.
Message 6 of 8
(4,321 Views)
Hi, does anyone know where I can purchase a PCI-6031e or PCI-6033e card?
Message 7 of 8
(3,685 Views)
Why would you hijack an old and unrelated thread for this question? Start New thread, please. Can everyone assume you've already searched ebay?
Message 8 of 8
(3,676 Views)
