How do i control a KYOWA PCD-320A without a header file?
I am trying to interface a KYOWA PCD-320A Sensor Interface to a PC through LV. I suspect that the device is not supported. I would like to know how to do this with a PCD.dll provided in the software bundle. (no header file was included) Any suggestions?
(3,014 Views)
You don't need a header if you have documentation on the dll. Even with a header, you would need documentation. That is something you need to ask the vendor about.
(3,008 Views)
