How do you Configure Analog Output Pins
I have a PCI-6023E with a BNC-2120. For some odd reason Labview doesn't recongize the Analog Output pins on the DAQ card at all. I have DAQ700 with a CB-50LP with the exact same problem. The Coutners,Digital I/O and Analog Inputs work just fine. Also Properties and Test Panel in MAX don't recongize the pins either. I have Labview 6.0 with Win98 and 2k. What could cause this to happen?
(2,693 Views)
The 6023 has no analog outputs (According to page 307 of the 2001 NI catalog). Therefore, I would not expect MAX to see any.
Sorry,
Mike
As a Wolfpack alum I am curious what your nom d'plume means.
(2,693 Views)
