How do you include the run time engine while creating an executable
I created an executable for a project and the installer file. When I tried running it, it said it cannot find the run time engine. How do you include the run time engine with the installer?
(3,253 Views)
Open the Installer properties and select the Additional Installers category. In the Installers to Inlcude window, make sure the run-time is checked. Select other drivers as needed.
p.s. You misposted this question to the multi-function DAQ board. It belongs in the LabVIEW board.
(3,250 Views)
That was already checked. It still doesn't work
(3,227 Views)
Do you observe the run-time engine being installed? If I remember correctly, the installer does provde this status. Have you search the hard drive for the run-time and are you installing the program (i.e. c:\program files)?
(3,217 Views)
