How do you make a DAQ card output zero volts, or no output, when an error occurs?
I'm trying to make it so that when the VI I have encounters an error, the analog output goes to zero volts, or no output, rather than the last value when the error occurred.
Is there a way to do this?
The card I'm using is a NI-DAQ 6063.
(3,007 Views)
All you have to do is wire your error cluster to the selector of a case statement and inside the case statement, place a DAQmx write with a 0 value. Pass in the task you originally created or use another DAQ Assistant.
(3,000 Views)
