How does the device routing work
please can you tell me how works function connect and disconnect terminals exactly. I mean how is this connection realized? Is it matter of switching some gates or something like this?
Thank you Martin
(3,225 Views)
Hi Martin,
If you are referring to how relays work then please refer to this Developer zone article.
I am not sure I understand the question.  Could you please answer the following questions so that I can provide you with a better answer?
  1. What hardware are you using?
  2. What language are you using to program your hardware?
  3. Please clarify what connection the function is making.
Ima
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
(3,193 Views)
