nikolsv,
In order to do continuous, correlated digital output without on-board
regeneration, you must first fill the entire output buffer of your card
with data before starting the task. For your card, this is 2047
samples. Afterwards, you can then perform digital writes in the same
manner as analog output. Keep in mind, you must output the data in
software as fast as the card empties it's buffer. Note: this method may
be changed in future versions of the DAQ driver.
I have created a simple example which first fills the output buffer
with all 0s, starts the task, then begins a loop which continuously
updates the data 100 samples at a time. Because digital operations do
not have their own clock, you will also need to set up a counter task
to provide one.
Hope this helps,
Ryan V.
Ryan Verret
Product Marketing Engineer
Signal Generators
