How get usb DAQ assistant?
I try to make program to used my usb-6009 with Labview 7.0 but the DAQ assistant don't find the usb-6009.
I would make a program to acquire 2 min. data in 1 only graph,and make a switch to control output.Can you help me ?
(3,431 Views)
the usb-6009 uses the daqmx base driver, not the daqmx driver. the daq assistant is a daqmx technology and that is why you cannot see the device using that.
Go to Start menu>>programs>>national instruments>>daqmx base and you will see example code etc. used for this. let me know if you have any other problems or queries.
(3,419 Views)
Thank you for your help
(3,400 Views)
