How long does it take to load an FPGA bitstream from software?
If I have a NI DAQ card with an FPGA, like a FlexRIO or PXI-7842R, how long does it take to download a bitstream to the device from software? Is it a few seconds or less? Does it matter how "full" the FPGA is?
(Let's assume for a moment that I do not want to load the PROM, so that I can have some more flexibility).
(4,681 Views)
The FPGA 'fullness' does not matter.  FPGA bitfile sizes are based only on the size of the FPGA itself.  So a LabVIEW FPGA product with a Virtex 5 LX110 FPGA will take longer than a product with a Virtex 5 LX30 FPGA.  You can see the Virtex 5 FPGA bitfile sizes (aka configuration memory) in the product table at the following link.  They are on the order of a few megabytes.
http://www.xilinx.com/publications/prod_mktg/V5_LX__TXT_psm_table.pdf
PXI LabVIEW FPGA products (like FlexRIO and 784x/5x, etc.) can load the FPGA via the PXI interface (33 MHz x 32 bits).  I'm not aware of characterization data for FPGA load time via PXI/PCI, but I think its in the 100's of ms range.  Rough calcs support this, for example:
An LX50 bitfile = 12.6 Mb = 412877 x 32-bit words.  If we assume it takes 10-15 33MHz (30 ns) cycles to write each word, then the total config time would be around 200 ms.  The LX110 would be around 1/2 second with these assumptions.  These are rough numbers, there will be some software overhead, but I think this is the correct order of magnitude.
Note - PXI/PCI bus traffic can affect the load time.
I think you can safely assume FPGA download will be at most a few seconds (as long as the PXI bus is available).
(4,671 Views)
