How to Bridge - Continuous Input.vi Multiple input graphs ?
Greetings!
I have 4 load cell force sensors and I used example: Bridge - Continuous Input.vi
Is it possible to visualize the output graphs of two load cells simultaneously using the example: Bridge - Continuous Input.vi? Currently, the example only displays one graph for a single load cell. I would like to see if it supports plotting graphs for two load cells simultaneously.
I want to select an additional Physical Channel and add Acquired Data in the picture below.
Thanks.
(895 Views)
Simply select multiple channels using the Browse option from the drop down menu. The waveform chart in the shipping example can display multiple waveforms in a single plot.
NI-DAQmx Syntax for Specifying Physical Channel Strings
https://tmesystems.net/
(850 Views)
