‎03-10-2011 06:31 PM
I have started a new project where I have to control the valves operation through Labview 2009,using PXI 1031, NI 5105(Digitizer) and NI 6251(M-series DAQ).
The valves I need to control using the labview are:
a) Pressure Reducing Valve (open & close)
b) Remote control Valve(On & Off) with in-built actuator
c) Flow control valve(open, semi open, partially open, semi close, partially close, fully close), 1%, 2%, 3%..etc
d)saftey valve (opening closing depending on increase in pressure from certian limit)
I hav eto control
a) Hydraulic pump operation with in built gear-box
Please let me know, how should l develop the VI for all? How to get started?, any helpful links? If there is any example code?
Its little urgent !
‎03-10-2011 08:25 PM
‎03-10-2011 08:41 PM
That message was for Anita..I think we have a right to post our query to the LV experts, until we find a satisfactory solutions.
If you feel irritated than pardon me.
‎03-10-2011 08:49 PM
The post was in no way intended for 'Anita'. You posted the exact same question multiple times and that would be considered rude in any forum. It is a waste of everyone's time. Most of us are volunteers, you know. Wasting the time of the LV Experts is not a way to get your question answered by a LV expert. I don't intend to spend any time on this or further questions of yours.
‎03-11-2011 12:58 PM - edited ‎03-11-2011 01:00 PM
OP also has no issue with PM for help with this issue.
p.s. Dennis, he said "Experts", so technically, no time wasting has occured.
‎03-14-2011 12:11 PM
KRAZE4LV,
As far as setting up your system goes, we do have many good examples. You can find a few by going to Help>>Find Examples in LabVIEW, and then looking under the Hardware Input and Ouput folder under DAQmx. There are also some community contributed examples at ni.com/examples.
And although this tutorial is a little old, you may find it useful - Complete Industrial Digital I/O and Counter/Timer Tutorial.
If you have any more specific questions, feel free to post them on the forum.
Elizabeth K.
National Instruments | Applications Engineer | www.ni.com/support
‎03-15-2011 12:35 AM
Thank you Elizabeth for the links! I will go through them.
