How to Displayed
Hai,
       i would like to displayed all waveform signal in one waveform graphplate.
 if i choose any one signal in graphplate i'll display that particulorlly
waveform only. i attached example code.vi , i generate the three type
of waveform than displayed the selected waveform. but i con't display all signal
at same time. how can i display this requirement.replay to me very urgent.
thankyou
krishnakumar.p
(3,260 Views)
Hi Khristnna,
I'm not sure what you exactly wish for but I enclose a modified version of your project which let the different waveforms to be included in the graph.
Hope it helps,
Pelle S
Account Manager
National Instruments Sweden
(3,251 Views)
Hi  pelle,
Thankyou for your enclosed  modify verson pro, but i con't open this code
because now iam using labview 8.20 ver,so plz convert this code and another
doubt how to save waveform graph with neumeric data at the same page
(graph plot and neumeric values) the file formet is *.XL or *.Doc
thankyou
krishnna
(3,225 Views)
Here you go.
You can use write to measurement file express vi (saves in .lvm just like .txt) and merge the two signals for insance.
Hope it helps
Pelle S
Account Manager
(3,211 Views)
