02-28-2007 12:28 PM
03-23-2007 06:14 PM
Hi Sunny,
NI doesn't make one of these converters, but I tried searching for one and was unable to find it. If you are using a PXI-1033, you will be using an external PC to control the chassis (instead of an embedded controller). If you are using a PC instead of a laptop, you should have PCI slots in the PC that you could use. Unless someone in the community has used a PXI-PCI adapter, I don't have an answer for you. ![]()
03-24-2007 06:56 PM
03-27-2007 11:12 AM
10-27-2010 10:50 AM
Hey Sunny,
Did that EKF board slide into the PXI chassis just like a standard PXI card, or did you have to interface it with the chassis in some other way?
Josh
07-25-2018 05:35 AM
While this is an old thread, I was hoping to find out how the adapter worked. Any unexpected problems you had to address?
07-26-2018 03:30 PM
I am not sure if it worked or not, I recommend you also to create a new forum, soo other people can see it as a different guest, however I found some information on the following link that tell that it is not supported, so it is hard to tell if it will work or not.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019KjSSAU
