How to analog output a signal and its negation simultaneously?
I'm using the 6024E and am trying to send out a signal with one analog output.
However, at the same time, I would like to send a negation of this signal from the other analog output.
This seemed straightforward until I realized that only one clocked task is supported at a time.
Any suggestions would be most appreciated...I've attached the vi I thought would (but now realize will never) work.
Thanks!
(3,076 Views)
Accepted by topic author ptuinluff
You should be able to put both channels in the same task.  Didn't have time to test this, but it should work.
Message Edited by centerbolt on 02-12-2009 05:41 PM
(3,063 Views)
That worked perfectly, thanks!
(3,058 Views)
