How to apply user defined scale table or fomular in NIDAQmx?
Hi.
I got a some problem to show measurment data with NIDAQmx. As you knew well, NIDAQmx just support ANSI C api for visual studio 6.0.
So, i tried to build an application with ANSI C API on visual studio C++.
But i couldn't find out some useful example to convert voltage data from USB-6210 device to linear scaled integer like 0 to 65535.
Would you give me some idea or example ?
Best Regards.
IlHwan.
안녕하세요.
NIDAQmx 에서 ANSI 로 해보고 있는데요.
AI 채널에서 전압으로 들어오는 것을 0 에서 65535 로 변경하는 것을 Custome Scale 로 될 것 같은데, MAX 나 LabVIEW 외에는 예제가 없군요.
제 생각에는 다음 함수를 사용하면 될 것도 같은데, 어떤 방식일지 판단이 서질 않아서요.
도움 부탁드립니다.
DAQmxSetScaleLinSlope
(2,911 Views)
I'm not quite sure what you are asking for.  Are you doing analog input and wanting to find the raw, unscaled (16-bit integer) values that are measured by the ADC?  What are you trying to do?  What is your application?
Andy McRorie
NI R&D
(2,896 Views)
