How to calibrate DAQCard - 6024E with San Diego Instruments Startle chambers?
I recently installed a DAQ card into my desktop. I'm now working on setting it up to work with San Diego Instrument's Startle chambers. I needed to know what steps to take to configure (if necessary) and/or test if the card is communicating with the chambers correctly.
(3,120 Views)
The card itself can be configured and tested in MAX (Measurement and Automation Explorer). As far as interfacing to third-party hardware, that question might be better asked of the vendor of the third-party hardware. Did they provide you with any kind of setup procedure or software that you can use?
(3,107 Views)
Welcome to the discussion forums, bmedina!
The DAQCard-6024E can measure voltage signals from any external voltage source between -10 and 10 V. It can also output voltage signals (analog & digital). How you plan to interface with the startle chamber is going to determine how to help you get started. Please clarify how you intend to interface with the chamber so we can best help you. You can also find many resources (tutorials, examples, etc.) for a variety of applications at www.ni.com/devzone.
I’m unclear what you mean when you say you want to calibrate your card to the San Diego Startle chamber. Typically, calibration is a procedure of reading offset and gain errors from an MIO board and updating special onboard analog calibration circuitry that will correct these errors. Is this what you mean by calibration?
Dennis mentioned using MAX to test the card. This can be done with a test panel for the device. Under the list of devices, right-click your device and click “Test Panel”. You can read in the raw signals to see if you are getting the results you expect. Once you know it is working, you can move to the next step of creating your program in LabVIEW, etc.
To help us see the big picture, please describe your setup as completely as possible, including your operating system, LabVIEW version, device driver & version, hardware interface (PCI, PCMCIA), etc.
I hope this helps get you started. Please repost with further questions after looking at the linked resources.
Mark E.
Precision DC Product Support Engineer
(3,091 Views)
