How to check the Digital Output in USB 6009
How can I send a 4 V pulse from the digital output of my USB 6009 ?
At the moment I created a DAQ Assistant to generate a digital output (line). Then I created a control and entered values between 0-5. The DAQ Assistant is within a while loop. I try to check across the pins using a multimeter the generated voltage but nothing is showing. Apparently I cannot choose continuous sampling and only 1 sample(on demand) either. Is the sampling rate too fast for the multimeter to detect or am I doing the whole process completely wrong ?
I would really appreciate any remarks or links to tutorials on this issue.
Cheers,
A desperate individual trying to get his project done.
(3,079 Views)
The easiest thing to do is to go into MAX and run the test panel.
(3,065 Views)
