How to connect 3 (true) differential signals to a 6366 with BNC 2210?
I need to meassure 3 differential (not three floating) signals with a NI USB 6366 & BNC2110 ...
in the FS setting it seems that all negative inputs are connected to the same AGND via 5k and 100nF  building a asymmetric load to my sources. 😞
However since I don't use AO (and the 6366 measure differential anyway) it should be possible to  measure differential in the GS (ground referenced) mode and use two 1M resistors per channel as bias drains to AGND, rigth?
That way I should have a symmetric load.
Greetings from Germany
Henrik
LV since v3.1
(3,590 Views)
Update : I used a SCB68 with the 6366 with the two 1MOhms and runs fine 🙂
Henrik
LV since v3.1
(3,568 Views)
