How to continuously output a Digital buffer/pattern/FIFO (Waveform) using .Net on PXIe-6363
Hi forum..
Been trying to learn how to write a .Net based code to continuously output a digital pattern, defined as a integer data (Play the bits out, one by one).
I've already found the way to do it using Labview (Examples -> "Digital - Continuous output.vi"), but can't fine the proper .Net commands to apply the same code.
please help..
Cheers,
Ran
(1,864 Views)
Have you checked .net examples located in C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DotNET4.5 ?
(1,736 Views)
