How to control configuration of multi channels analogue inputs directly from a front panel
HI
sorry for my english; my probleme is how to control configuration of multi channels analogue inputs directly from a front panel I use a NI usb 9234card with 4 channels and I want to control them directly from my front panel so I use DAQmx create virtual channel.vi I can control it in block diagram from polymorphic selector by my probleme is that i will deploy my application so I want control the configuration of each 4 channels from my front panel so for example I want channel 1 like input analog accelerometr and channel 3 like voltage input but i have to set it by a front panel contol.
HELP ME PLEASE !!!
(2,973 Views)
Right click on the physical channels input terminal of the DAQmx Create Virtual Channel VI and select Create >> Control. This will put a control on the front panel. This will allow you to select the channel from the front panel when you run the application.
Nathan S.
(2,969 Views)
It's typically discussed how to conifgure a multichannel setup from the back panel using physical channel syntax (as explained here). However, how can I configure and convey the same multichannel setup via the front panel so the user can select the multichannel configuration using the one control drop down menu?
(2,815 Views)
