How to execute a callback when a DI signal changes value
Hi all:
I'm using the Qmx library on the PCI-6220 ADC device. My problem is that I want to monitor a digital input signal. I want my application to be interrupted when a change in the value of the digital input signal is detected. How do I do this? I'm new to this field so this may be a very easy question. The traditional NI-DAQ had an api call to register a callback function - I don't see anything in the DAQmx library that does that. From what I read the Traditional NI-DAQ and the NI-DAQmx don't work together without reconfiguring the device. I've written all my code using the DAQmx and want to stick with this exclusively if possible. Help!
Greg
(3,663 Views)
Since you're using a 6220 (M-series device) you *have* to use DAQmx.
Events were added to NI-DAQmx in version 7.5; be sure you have the latest version.
You need DAQmxRegisterSignalEvent, found in the DAQmx C documentation under Task Configuration/Control->Events.
BUT, if I understand things correctly, the 6220 doesn't support change detection on DIO lines. I can't recall now how I found this out.
John Weeks
WaveMetrics, Inc.
Phone (503) 620-3001
Fax (503) 620-6754
www.wavemetrics.com
(3,656 Views)
See the thread http://forums.ni.com/ni/board/message?board.id=250&message.id=15722
It confirms that you can't do change detection with M-series cards, but gives hope for the future.
John Weeks
WaveMetrics, Inc.
Fax (503) 620-6754
www.wavemetrics.com
(3,649 Views)
Another possibility is to use the serial or parallel port.  Have the TTL signal drive a mosfet that shorts together the serial port handshake lines and then set up a handshake OnChange event.  The parallel port directly supports one of its input lines as an interrupt line.  The ease of implementing this depends on your development language.
Steve
(3,639 Views)
