How to export a clock
I have a very simple question.
I am using PCI 6534 and I would like to export the sample clock to an output pin.  The code is as following:
    DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
    DAQmxErrChk (DAQmxCreateDOChan(taskHandle,"Dev4/port0/line0:7","",DAQmx_Val_ChanPerLine));
    DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle, NULL,1000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000));
    DAQmxErrChk (DAQmxExportSignal(taskHandle, DAQmx_Val_SampleClock, "/Dev4/pfi2"));
In the last line, I exported the sample clock to pin pfi2.  But when I hooked up an oscilloscope to pfi2 (pin 2 on PCI 6534) I observed no clock signal.  All I saw was a signal at ground voltage level.  What's wrong?
-Andrew
(4,142 Views)
Hello Andrew,
The sample clock for your task will not actually start until you start the task.  Try including a DAQmxStartTask function call after the configuration function calls you've already made.  Let me know if that doesn't solve the problem.
Travis G.
Applications Engineering
www.ni.com/support
(4,126 Views)
Hey Travis:
Yes I started the task using DAQmxStartTask just as you described, but still the sample clock signal was not present.
Thanks!  Please continue to help me as I am very stuck at this point.
-Andrew
(4,122 Views)
Hello Andrew,
You may just not be seeing the sample clock because of a sampling rate of the oscilloscope you are using.  The duty cycle of the sample clock pulse is extremely small, and hard to capture with a scope.
Even though you can't see the clock on a scope due to the small duty cycle, it is probably being generated from that PFI pin.  If you have a second DAQ device with a counter, you can use that to count the edges on the PFI line in order to verify the sample clock is being exported.  I hope this helps,
Travis G.
(4,107 Views)
I see, that's correct.  Thanks,
-Andrew
(4,100 Views)
