How to find USB DAQ 6009 port address (ex. dev1, dev2) automatically from Progra
How can i make a program which will search the Port/Device ID for USB 6009 automatically and start acquiring data from the device?
(4,068 Views)
Use DAQmxGetSysDevNames function to get the names (Dev1, Dev2, etc) of all devices connected in the system, and then use DAQmxGetDevProductType function to identify the type (USB-6008, USB-6009, etc) of each device.
Then you can select the desired type and start a device-dependent data acquisition.
- George -
(4,044 Views)
Why would you WANT to make a program to do that!!!!!  National Instruments Already DID!
the Only question to answer here is did you want the device manager to launch a LabVIEW, Test Panels, or Signal express?
YOU CAN EVEN LAUNCH YOUR OWN VI.
(4,036 Views)
