How to generate a continuous waveform on the oscilloscope using USB 6009?
Hi all
USB 6009 is not compatible with traditional DAQ or DAQmx.How do I generate a continuous waveform on the oscilloscope using this device and DAQMX Base?
Any help would be appreciated.
Thanks in anticipation.
P
(3,130 Views)
Hello pushD,
If you have installed NI-DAQmx Base, you should have examples (in Windows) here: Start>>All Programs>>National Instruments>>NI-DAQmx Base>>Examples>>LabVIEW 7.x>>Dynamic>>ao. There are a couple analog output examples there. I would recommend taking a look at those. Hope that helps!
-Alan A.
(3,122 Views)
